Brief Description: Drllng tank access hole cover plate
Took the cover plates to my shop in Michigan, where I have a mill available in my shop and it is a lot easier to use a deviding head to get the 72 degree hole spacing. BJ suggests to use a sealer to seal the screw heads against gasoline leaking out. I preferred to use an O-ring solution which I saw on other builders website.
