Brief Description: attaching cabin shells to seat pan. Installing nut
Today I took off the other cabin shell to install the nut plates on the seat pan. I also removed the seat pan from the frame, bacause I could not install the nut plates at the top of the seat pan back rest while it was installed. Again I used solid flush rivets. I installed the 5 additional nut plates on the sides plus the 2 nut plates on top of the seat pan. I also added nut plates on the cabin shells and completed adding floating #6 nut plates on the cabin on the chin window frame.
adding the last nut plates on the chin window frame
