GOTTFRIED'S WEB SITE
Date:  12-3-2015
Number of Hours:  5.00
Brief Description:  attaching landing gear to frame
Checked one last time all dimension between gear and frame making sure everything is perfect. Next I drilled the holes for the rear gear hoop to frame attachment and inserted bolts. Next I determined the location to be drilled to attach the front gear hoop to the frame using a 1/4" transfer puncg which I put in the tube in the trame. Using a large clamp on the center punch marked the center of the hole to be drilled. Next i drilled the 2 holes in the front gear shoes. Cut the 2 spacer bushings for the rear gear and installed them. Inserted all bolts and nuts and checked all dimension. Everything looked good and the gear installation to the frame is finished.
Drilling holes for rear gear
cutting spacer bushing to length
Drilling front gear shoes
