Did inventory of grommets and studs and discovered a discrepancy. Stud count was correct, but was supposed to have 34 SK-OSG1-8 gromments (short; no notches) and 2 SK-O18-S grommets (tall; with notches). What was packed was actually a mix of 14 -8 grommets and 20 -S grommets in one bag, and 2 -S grommets in a separate bag. Not sure about interchangeability; will call Skybolt and discuss. Proceeded with assembly using all -S grommets. Grommet holes needed to be reamed slightly and sanded smooth to improve fit. Studs and grommets were inserted into holes with receptacles and tightened to correct fit; pins were removed from locking springs and receptacles locked in place. Removed remaining inserts and clecos and repeated sequence of drilling, reaming, smoothing, riveting, reassembly, adjustment and locking. Removed cowling from table and reassembled on fuselage to check fit; nominal. Horizontal fasteners complete.
