MARTIN'S WEB SITE
Date:  5-1-2020
Number of Hours:  0.00
Brief Description:  Baffle Work pt. 117
Final drilled and countersunk clamping strip mounting screw holes in bottom cowl inlets. Mixed flox and applied to inside surfaces of both inlets. Inserted screws, slipped seals and clamping strips over screws and tightened down clamping strips with stop nuts and washers. Wiped excess flox off seals; made sure that errant screw hole in right side was properly filled. Shimmed upper corners of clamping strips with card stock to press seals firmly against cowl lnlets, which will allow flox to conform to correct shape. Torqued and sealed mounting screw nuts.
