Sanded inner edges of top and bottom composite boards to refine fit around air filter. Drilled holes in corners to set alignment pins when parts are joined. Sealed inner edges with epoxy. Laid up another composite board which will be trimmed and epoxied to other boards to complete new air filter tray. Cut foam out for fabricating top and bottom flanges that will hold tray in place.
