Removed baffles. Made final trim on both aft baffles and right side baffle; smoothed edges. Left aft corner clearance will be less than 3/8", but cannot be made any lower. Disassembly with parts clecoed together proved that right aft and side baffles can be removed while joined. Prepped both mating surfaces, applied thin coat of high temp gasket maker, clecoed and riveted right aft and side baffles together.
