Brief Description: Throttle Bracket fitting, pt. 1
Initial test fitting indicated what Showplanes suspected: as delivered, there would be clearance issues if the bracket angle was installed on top of the bracket. 1/2" displacement of the aft edge downward would solve the problem. Leo Knowlden bent bracket per my specs with sheet metal brake. More test fitting; bracket angle was bent slightly to offset bend in bracket. More test fitting; for ideal cable alignment with lever, bracket angle would also have to be angled laterally. Drilled new bolt hole in bracket to accomodate realignment. Martin 1.5 hrs. Leo Knowlden 0.5 hrs
