MARTIN'S WEB SITE
Date:  5-10-2019
Brief Description:  Fabricate Antenna Doubler Plate
Did research on Garmin GA 35 GPS antenna installation and templates. Learned the template I had been using wasn't for the GA 35; although the hole pattern was correct, there was an incorrect conversion spec on the antenna hole. Fabricated a doubler plate per correct Garmin specs.
