Flaps also worked, but travel is reversed. That can be fixed during calibration. Fuel sender and engine circuit testing may also have to wait until final assembly and calibration. Fuel boost pump still did not work; circuit breaker popped. Disconnected pump ground wire and checked voltage at the motor; power ok. Did research; pump should not be operated without fuel. Suspect the dry and preserved pump may be sticking. Battery backup of G5 worked correctly on shutdown. Created video of testing procedures and posted to YouTube channel; link below.
