MARTIN'S WEB SITE
Date:  4-6-2018
Number of Hours:  3.00
Brief Description:  Miscellaneous Work pt. 2
Fabricated polypropylene spacer out of cutting board material to fill tie down strap gap created by shorter battery. Cut rubber hose insulator segments for tie down bolts. Fabricated longer battery/master cable with lugs and heat shrink tubing. Chased threads of upper nut plate before bolting starter solenoid to firewall; torqued and sealed.
