Brief Description: Transponder and EIS Brackets pt. 4
Prepped and primed transponder rack brackets and riveted to forward baggage side panel. Laid out wire passthrough on triangular flange of panel. Drilled pilot hole, completed to 7/8" and cut out 3/8" notch from edge of flange to hole. Fit rubber bushing and check fit on fuselage.
