Bent fuel float rods per plans; installed rods in senders. Determined left/right sender assignments; zip tied each sender to its cover plate. Checked resistance of each sender with ohmmeter; both checked out at 31 ohms in the full position and 248 ohms in the empty position. Van's specs called for 32/240, so both senders are within a correct range.
