Marked outline of T-405 angle tabs on each tank attach bracket. Removed brackets from fuselage and laid out location for pilot hole for attach bolt that provided maximum edge distance for all tabs. Drilled #40 pilot hole in each bracket with drill press. Bolt brackets to fuselage and match drill #40 holes in each T-405 angle tab.
