Found myself in a Shipbuilder's Conundrum: the plans clearly state that the aileron pushrods should be placed in the wings before fitting to the fuselage if there isn't enough space around the aircraft to bring them in from the ends. Somehow that got by all of us when we fitted the wings. I had hoped I could install them from the bottom, but that isn't possible. Three choices available: remove the wings, install the pushrods and refit the wings; do all the aileron and flap work later... or drill a hole in my wall and feed the pushrods through the holes. I chose to drill a hole in the interior wall between the shop and garage adjacent to the right wing.
