MARTIN'S WEB SITE
Date:  3-18-2017
Brief Description:  Hinge Pin Modifications pt. 3
Paired off hinge pin retainer parts and clecoed together. Countersunk the back side of the rivet holes by hand and set rivets to assemble each hinge pin retainer. Prepped and primed the front side of retainers. Took measurements and bent hinge pins to correct shape for using retainers; cut bent ends to proper length.
