Masked fuselage for adhesive work and adjusted masking on windscreen. Practiced installing windscreen to determine the best method of setting the windscreen down correctly with adhesive in place. Prepped and cleaned mating surfaces; applied 3M AC-137 adhesion promotor to support hoop and top forward fuselage skin along contact lines. Mixed AC-251 adhesive and applied in a bead along contact lines. Set a toothpick in top screw hole to help with alignment and carefully lowered windscreen into place, using toothpick to align other four holes and spread adhesive on countersunk surfaces. Started all five mounting screws and checked alignment; wiped excess adhesive off of bottom edge and formed a consistent fillet. Lightly cinched the screws down to secure the windscreen. Taped and clamped aft bottom corners for best adhesion.
