Aluminum template for aftmost holes didn't work for last two holes in right skirt. Skirt is held away from the canopy frame tube in that location; nicked the frame tube with the bit, scraping off the powdercoat. Three mis-drilled holes on the right side will need to be patched and redrilled. Notched bottom front corner of left skirt half, set on frame and match drilled #30 holes along top edge. Also drilled hole for canopy latch handle. One mis-drilled hole on left side will require patching and redrilling. Also all temporary rivet locations need to be drilled. Some shimming will be required for lower skirt rivets. Aftmost #30 holes will be drilled once skirts are trimmed to fit together and correct placement can be guaranteed. A better way of templating the aftmost lower skirt rivet holes will have to be determined.
