Brief Description: Wheel/Brake/Fairing Bracket Work pt. 4
Sent photo of mis-drilled jack point bracket (on right) to Donnie Eccker. At first he thought it would be ok, but his machinist advised him to replace the mis-drilled part. He's sending new ones out; I'll send the old ones back. Ordered engine oil, wheel bearing grease and brake fluid from Aircraft Spruce. Called Barrett to check on break-in oil specs; eventually settled on Aeroshell 100 mineral oil for break-in and W100 after that. Called MATCO for clarification on brake caliper installation. Sent an email to Van's Builder Support regarding mods to the brackets for caliper and gear leg clearance issue. Went ahead and did the modifications as shown.
