Left gear leg pulled into place on the wear plate as Grove said it would. Gaps are .015' forward; .025" aft. These are slightly under Van's specs (.030" min) but the Grove gear and brackets are larger than Van's stock pieces and the torque is correct. May check with Grove on their gap tolerances.
