MARTIN'S WEB SITE
Date:  7-6-2018
Number of Hours:  3.00
Brief Description:  Disassembly pt. 3
Removed upholstery, front seatback and seat panels. Struggled with stripped screw in seat support nut plate. Had to cut head off screw with Dremel tool and cutting disc. Wrecked left seat support bracket and damaged left console cover in the process; only way of removing parts to get to stripped screw. Hammered/drilled/punched/wiggled screw stub repeatedly until hole was cleared. Reamed hole with #19 bit and cleaned up mess.
