Brief Description: Cockpit Heat Selector Box Work pt. 1
Examined installation instructions for TG-10 cabin heat bypass selector box and realized I would need to design a different actuation system to eliminate the possibility of the cable interfering with the rudder/brake pedals. Cut angle extension off the flapper lever and drilled a new cable hole. Checked angle of travel on cardboard template and designed an anchor bracket for the repositioned cable. Assembled and bench tested.
