MARTIN'S WEB SITE
Date:  2-8-2018
Brief Description:  Miscellaneous Work
Created PDF file for ordering custom decals for jack panels, fuel selector valve, aileron trim and elevator trim from Aerotronics. Match-drilled, deburred and dimpled #40 holes in iPad mount doubler plate and right mid cabin cover for flush rivets. Machine countersunk rivet holes in reinforcement angle. Prepped and primed reinforcement angle and riveted doubler plate and angle to right mid cabin cover. Some rivets set badly, sitting proud; had to drill out and set new ones. Installed power stabilizer on mounting plate and upper aft brace.
