MARTIN'S WEB SITE
Date:  9-8-2017
Number of Hours:  4.00
Brief Description:  Miscellaneous Work
Modified low jig table for vertical stabilizer with riveted attach angle. Match-drilled holes in SV-1 NACA vent and fuselage using wing vent as template. Dimpled rivet holes in fuselage; hand-turn light countersink on all NACA vent rivet holes. Mixed Pro-Seal and ran bead around perimeter of vent. Affixed screen to bead on vent, ran second bead and affixed assembly to fuselage, using scrap mandrel to center holes. Insert blind rivets into rivet holes and placed washers around shop head of rivets for support. Riveted vent and screen to fuselage and cleaned off excess Pro-Seal with solvent. Blind riveted ground adjustable rudder pedal attach angles to fuselage floor. Grind off two unbroken mandrels on attach angle blind rivets and smooth heads of flush blind rivets on duct assembly.
