Knocked out blind rivet mandrels in aft holes and initially match-drilled #40 for cleco use, making sure attach angle spacing was accurate. Match-drilled two additional #40 holes to confirm mounting configuration. Removed angles, marked forward existing rivets with red paint and reinstalled angles. Paint on rivets made marks on underside of angles, helping to determine how much to trim for clearance. Laid out and drilled #40 holes in revised blind rivet location for forward holes. Cut, trimmed and smoothed forward tips of attach angles to clear existing rivets. Clecoed both angles in place, checked dimensions and match -drilled remaining #40 holes. Final-drilled #30 all twelve inner holes; final-drilled #21 four end holes.
