MARTIN'S WEB SITE
Date:  8-22-2017
Number of Hours:  0.00
Brief Description:  Landing Gear Work pt. 5
Remounted gear using Van's bolts to check fit of legs, brackets, wear plates and alignment. Initial alignment specs using parallel channel method with channels level; measured with 100' tape:
5' 7-3/16 fore and aft on channel ends for zero toe in/out.
14' 3-9/16 from front of gear leg bottoms to back of tail spring mount for centering.
