MARTIN'S WEB SITE
Date:  8-4-2017
Number of Hours:  0.00
Brief Description:  Mount Vertical Stabilizer pt. 7
Limited access requred the removal of the vertical stabilizer from the fuselage to match-drill the top four rivet holes. Unbolted rear spar and removed four clecos holding the attach plate to relocate vertical stabilizer, clamping it to the table in order to drill the holes with angle drill and shortest #30 bit. Removed attach plate and spacer from vertical stabilizer and clecoed attach plate back onto horizontal stabilizer front spar. Finish-drilled to #12 for bolts. Removed attach plate and deburred all drilled holes. Prepped and primed attach plate and spacer.
