Brief Description: Mount Vertical Stabilizer pt. 6
Ran thread through center of all three sets of rudder bracket bolt holes, making minor adjustments to make sure rear spar was straight. Double checked measurements on all three axes and clamped tight. Match-drilled lower seven of the eleven #30 rivet holes through attach plate, spacer and front spar, putting clecos in each drilled hole.
