MARTIN'S WEB SITE
Date:  5-8-2017
Number of Hours:  5.00
Brief Description:  Floor Work Pt. 4
Disassembled parts. Machine countersunk floor support angle and nut plate rivet holes in seat rib angles. Drilled #40 holes for nut plates for front bolts of flap bearing block using angle drill and modified screw to hold nut plates. Countersunk rivet holes using adapter and deburring driver. Did research in setting rivets in close quarters; modified vice grips to squeeze rivets. Separated and deburred all floor stiffeners. Clecoed left and right floors together and clecoed stiffeners to floors.
