MARTIN'S WEB SITE
Date:  7-19-2019
Number of Hours:  1.00
Brief Description:  Vertical Tail Test Assembly
Needed to check planned tail strobe wire routing. Removed rudder and bolted vertical stabilizer to fuselage, shimming underneath front spar for support. Mounted rudder to check fit of rudder with bottom fairing in place. Previous tail strobe cable routing plan is definitely less than ideal.
