Brief Description: Rudder/Stabilizer Tip Work pt. 10
Removed peel-ply and trimmed excess fiberglass from strobe area of rudder bottom. Drilled hole in adapter ring and soldered ground lead to ring. Cut out center hole of new fiberglass cap; drilled guide holes in two rivet locations and upsized holes to 1/8". Clecoed adapter ring to rudder bottom and match-drilled remaining rivet holes in strobe area of rudder bottom. Cut notch in bottom of center hole for ground wire clearance.
