When fitting the vertical stabilizer, the bottom of the leading edge wouldn't fit around the aft top skin. The affected area was relieved and deburred. All empennage components were refit to the fuselage. Fit was ok, but the bottom of the vertical stabilizer leading edge will need a bit more relife prior to final assembly.
