MARTIN'S WEB SITE
Date:  10-23-2015
Number of Hours:  6.00
Brief Description:  Trim Tab Assembly pt. 1
Dimpled trim tab skin, horns and bottom of spar. Machine countersunk top of spar. Masked and primed inner (bottom) end tabs of skin and bottom/insides of both trim horns. Riveted trim tab horns to bottom of skin, using CS4-4 blind rivet in aftmost hole. Riveted bottom of spar to skin bottom, using squeezer with some difficulty and bucking one rivet in forward end of long horn. Clecoed top of skin to spar and hinge, then drilled, deburred, countersunk and reamed blind rivet holes throught end tabs. Riveted top of skin, spar and hinge together. Set CS4-4 blind rivets in both sets of end tabs.
