Brief Description: Rivet Horizontal Stabilizer pt. 1
Trained Mike Oswald to buck rivets. Started with riveting HS-707 right rib to HS-801PP right skin top. Third rivet was nose rivet, and parts separated when rivet was set. Drilled out rivet - skin was ok, but rivet shank was stuck in rib, and riib was damaged from drilling. Finally removed shank; did research, and mulled over possible solutions to rib damage. Riveted HS-707 rib to HS-801PP left skin top. Took break; Mike left. Clecoed both left center ribs to left skin; reamed blind rivet holes to 7/64 and blind riveted left skin bottom to HS-707. Riveted front spar assembly and all left ribs to left skin. Blind riveted HS-707, HS-708 ribs and HS-702 left front spar together. Martin Filiatrault 4 hrs Mike Oswald 3 hrs.
