Brief Description: Refit Wing Intersection Fairing Gap Seal
Refueled tanks using 5 gallon jugs; fuel, transfer, repeat. Jug nozzle cap got caught on inner edge of fuel filler neck and detached; used copper wire and long needle nose pliers to retrieve. During flight on 6/22, heard a vibration which got worse. Found that the gap seal for the right upper wing intersection fairings had come loose. Loosened fairings, refitted gap seal, retightened fairings and applied PVC tape to seal joint. Will replace seals with longer 1-pc. strips in future.
