MARTIN'S WEB SITE
Date:  7-14-2020
Number of Hours:  2.50
Brief Description:  Canopy Work pt. 35
Got one set of holes drilled in frame and used strap duplicator to match drill lower corner of template. Realized that plates should have been match drilled to existing canopy holes. Fabricated four new templates, drilling only one starting rivet hole in each. Drilled holes in canopy frame, then used strap duplicator to match drill remaining holes in templates, with much better results.
