MARTIN'S WEB SITE
Date:  4-29-2020
Number of Hours:  1.00
Brief Description:  Baffle Work pt. 113
Removed center seal section from aft seals. Laid out and cut seals for both inlets from fabric supplied by Ted Gauthier. Removed bottom cowl and checked fit of seals with clamping strips. Alignment marks will need to be established on bottom cowl and seals before mounting holes can be match drilled.
