Cut templates for two parts that make up the custom fiberglass air filter mount; base and step. Cut four pieces of 1/8" thick foam; two pieces per part, which were epoxied together to make each part 1/4" thick. Initially attempted to wrap fiberglass around each leg of the doubled pieces that make up the open rectangle shape, but that didn't work. Cut strips of fiberglass and laid them up on the base, then epoxied the step to the base and added fiberglass strips to the top surface. Compressed parts between two flat surfaces to cure.
