Brief Description: Rudder/Stabilizer Tip Work pt. 11
Prepped mating surfaces of strobe area and adapter ring. Adhered ring to rudder bottom with RTV silicon and riveted ring in place. Mixed flox and applied to inside of strobe mounting area around pulled rivets to reinforce area. Check threads and clear with screw and isopropyl alcohol. Prepped exterior of area around ring; mixed more flox and spread around outer edge of ring.
