MARTIN'S WEB SITE
Date:  1-23-2019
Number of Hours:  3.00
Brief Description:  Throttle/Mixture Connections
Picked up coated brackets from Flow Coatings. Mounted mixture and throttle brackets to engine and completed assembly of cables, brackets and hardware using safety wire and cotter pins. Throttle bracket mounting bolts will be safety wired when additional drilled bolts are received from Van's. Mixture lever bolt may be replaced by shorter bolt in the future.
