MARTIN'S WEB SITE
Date:  1-14-2019
Number of Hours:  4.00
Brief Description:  Governor Solution pt. 1
There must be a better way; more research was done. Photos from other builders revealed that reclocking the aft case of the Jihostroj prop governor must be possible, despite the fact that it came safety-wired from the factory; there were no obvious screw slots like other governors and there were no indications in the Whirl Wind instructions or the Jihostroj documentation. Calls to Whirl Wind and inquiries confirmed that with all six screws loosened, the back case could be optimally positioned. Removed the safety wires, reclocked the aft case, tightened the screws, rewired the safety wire and tested the travel. Full fine pitch travel was ideal.
