Brief Description: Rudder - 12 - Trailing & Leading Edges
- Final rivetted the Rudder trailing edge. Not perfect but it turned out OK. - Rolled the leading edge of the Rudder. I was really worried about this based on the posts I had read on other builder's sites. I was very surprised to see how easy it was. I used a pair of visegrips on a 3/4" metal pipe for leverage. It turned out very nice. - Clecoed the leading edge. - Riveted the leading edge with pop rivets. Easy stuff... - Touched up the primer and temporarily installed the rod end bearings.
* WHAT'S LEFT TO DO: - Still need to put in a few MK-319-BS rivets where I couldn't get a bucking bar (they are on order). - Install the Rudder on the VS and fine tune the end bearings. - Install the fiberglass pieces (may wait until the end for this...also need the System 6 lights for the Rudder).
