Aircraft Projects
Date:  5-28-2007
Number of Hours:  5.00
Brief Description:  Right Elevator - 05 - Riveting Understructure
- Scuffed right elevator spar; ready for prep and prime.
- Dimpled right elevator spar.
- Finished dimpling trailing edge ribs with Vicegrip dimpler.
- Washed and prepped all right elevator skeleton parts.
- Primed right elevator skeleton.
- Dimpled right elevator skin; used Vicegrip dimpler on trailing edge.
- Riveted counterbalance ribs together (E-703 to E-704).
- Riveted reinforcement plates and nut plates to spar (E-610, E-611 and K1000-6 to E-702).
- Riveted on root rib (E-709) to spar (E-702).
- Riveted counter balance ribs onto spar (E-703, E-704 to E-702).
- Riveted on elevator horn (WD-601-P-1 to E-702 and E-709).
- Final drilled counter balance skin (E-713) top attach holes and dimpled for CS4-4 pop rivets.
- Deburred holes on counter balance skin and touched up primer.
*** NOTE: Need #10 and #12 tools to continue with right elevator. Still need to dimple counterbalance skin and countersink lead counterbalance weight.
Primed Right Elevator Understructure Parts.
Rivetting Right Elevator Understructure together.
