Aircraft Projects
Date:  3-7-2007
Number of Hours:  3.00
Brief Description:  Vertical Stabilizer - 04 - VS Final Assembly
- Finished dimpling the VS skin (VS-801)
- Attached the VS skin to the front VS spar assembly.
- Riveted the front spar and center VS rib to the skin (VS-702 and 708 to 801).
- Attached Rear VS spar and riveted the left side and both end ribs to the skin.
- Started riveting the rear VS spar on the other side but did not finish.
- About 30 to 40 minutes left to completion.
Riveting Front VS Spar to skins.
And the other side...
