Aircraft Projects
Date:  3-4-2007
Number of Hours:  4.75
Brief Description:  Vertical Stabilizer - 01 - VS Final Drilling
- Clecoed the Vertical Stabilizer (VS) stiffner to the VS spar (VS-808 to 803) and then the hinges to both (VS-410, 411 and 412).
- Match drilled the holes in one of the bottom hinge set brackets.
- Finished the edges and fluted all the VS ribs (VS-704, 705, 706 and 707).
- Clecoed the VS Ribs to the front and rear VS spars.
- Final drilled all hinges, rib attach points and spar stiffners.
- Attached VS skin.
- Drilled all holes in Skin with #40 bit.
- Marked all parts and removed skin.
- Disassembled VS & removed blue plastic.
- Ready for deburring, dimpling, countersinking, prep and prime. WOW!!! This thing is going together fast...
Building the VS Spar.
VS Understructure assembled and final drilled.
Put VS skin on understructure and final drilled.
