Removed the seat ramp to check for gas residue. Was none, cleaned many metal surfaces and vacuumed. Re-installed the seat ramp with a few screws.
Bob Thornton visited. had a nice chat about the plane and he said it looked nice.
Did a lifter test of cylinder 1 per the Rotax oil purge procedure. The lifters were not tight enough so need to do anothe engine run. Put the engine plugs in and cylinder 1 valve cover back on. Torqued per the specs.
