Greg's RV-12 Classic N719VA
Date:  3-27-2020
Number of Hours:  2.50
Manual Reference:  SB 16-08-01
Brief Description:  Remove the stabilator bearings per SB 16-08-01
Service Bulletin 16-08-01 step 3 to remove the stabilator bearings. Took me so long to fing the right bolt to use per the Maintenance manual page 5-20 on removal of the bearings. I was unable to go to Home Depot to get a bolt due to social restrictions of the Covid-19 virus outbreak. The reason for the SB is to then replace them using Loctite to fasten them in place to avoid future movement. Once I had the correct length bolt the bearings were extracted fairly easily.
