Greg's RV-12 Classic N719VA
Date:  5-10-2022
Number of Hours:  3.00
Manual Reference:  32-14, 37-09
Brief Description:  final tension of stab cables,misc.
Rechecked the horizontal stabilator cable tensions. Used Kent-Moore BT-33-750 cable tensioner for readings on the 1/8 cable scale.
Manual 32-14 step 8 inserted the locking clips into the turnbuckles. Made sure they are in and locked and took close-up pictures to verify.
Manual 37-09 step 2 trimmed and cleaned the tank sealant from the inside of the fuel filler tube.
Torqued the two seat belt back cable attachments to the fuselage to 65 in-lbs
Applied the blue wrap to the ELT antenna mount bracket.
clips locks in-place
clips locked in-place
