Manual 50-07 steps 1 - 6 attach choke cables to the carbs. Used heat shrink to protect the ends of the cables from freying.
Manual 50-04 step 2 finish, tighten cushion clamp for cables though the firewall
Manula 49-17 apply RTV to heater cable and oil line under the engine to avoid chaffing. 49-19 tightened cable clamp on the heater cable right side on the engine mount.
