Brief Description: torqued engine bolts, fuel line install, ignition
46-08 step 5, torqued the engine mount bolts to approx. 160 to 190 in-lbs. Inserted cotter key on castleated nuts.
Manual 46-09 steps 1 - 6, attach and torque to 90 in-lbs the VA-216 Fuel Vent line onto the block via the banjo bolt. Connexted the fuel vent line to the return fuel bulkhead fitting on the firewall and the fuel pressure sensor. Tightened with out torquing.
Manual 46-10 steps 1 - 7, insert the ignition wires into the A1 and B1 connectors. Ran the cables with a partial exposed shield under the ground clamp and torqued the clamp mounting bolt to 22 in-lbs using Loctite 222 as a substitute for Loctyite 221.
Manual 46-10 step 8 - partial step 13, connect ignition wires WH-J762 and 763 into the AMP connector. Securred wies with wire ties. Partial 13 needs a wire-tie added.
